BlueRose Technologies
Last activity: 10 Aug 2017 6:00 EDT
Production server got down and logs filled with these entries
2017-01-03 00:02:31,316 [.PegaWorkManager : 1] [ STANDARD] [ ] [ FPM:01.02] ( internal.async.AgentQueue) ERROR - Agent Pega-RULES #2: Code-.SystemIndexer encountered an execution error. Restarting after delay.
java.lang.NullPointerException
at com.pega.pegarules.session.internal.mgmt.Executable.runIncrementalIndexer(Executable.java:11105)
at com.pegarules.generated.activity.ra_action_systemindexer_bcf109e229b3b868311b17d40c4cf617.step2_circum0(ra_action_systemindexer_bcf109e229b3b868311b17d40c4cf617.java:234)
at com.pegarules.generated.activity.ra_action_systemindexer_bcf109e229b3b868311b17d40c4cf617.perform(ra_action_systemindexer_bcf109e229b3b868311b17d40c4cf617.java:86)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3505)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:721)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:602)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670)
at com.pega.pegarules.session.internal.async.Agent.queueBatchActivityForAgent(Agent.java:1504)
at com.pega.pegarules.session.internal.async.Agent.queueBatchActivityForAgent(Agent.java:1293)
at com.pega.pegarules.session.internal.async.AgentQueue.run(AgentQueue.java:792)
at com.pega.pegarules.session.internal.async.Agent.runAgentTask(Agent.java:936)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:221)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.invoke(AsyncServant.java:167)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor71.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
at java.lang.reflect.Method.invoke(Method.java:620)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.processRequest(PRAsync.java:155)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.AsyncTask.run(AsyncTask.java:64)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.RunnableWrapper.run(RunnableWrapper.java:71)
at com.ibm.ws.asynchbeans.J2EEContext$RunProxy.run(J2EEContext.java:270)
at java.security.AccessController.doPrivileged(AccessController.java:285)
at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:796)
at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java:222)
at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:206)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1881)
2017-01-03 00:02:31,349 [.PegaWorkManager : 1] [ STANDARD] [ ] [ xx:01.02] ( internal.async.AgentQueue) ERROR - Problem queue Pega-RULES #2: Code-.SystemIndexer will restart in 240000 ms
2017-01-03 00:02:40,801 [PegaWorkManager : 45] [ STANDARD] [ ] [ xx:01.02] ( internal.mgmt.Executable) ERROR - Exception
at com.pegarules.generated.activity.ra_action_systemworkindexer_f75cf336649533591314b343e81e15eb.step2_circum0(ra_action_systemworkindexer_f75cf336649533591314b343e81e15eb.java:213)
at com.pegarules.generated.activity.ra_action_systemworkindexer_f75cf336649533591314b343e81e15eb.perform(ra_action_systemworkindexer_f75cf336649533591314b343e81e15eb.java:86)
***Updated by Moderator: Marissa to add SR details***
The exception reported here is not related to the experienced issue.
Root cause of the issue was an OutOfMemory error caused by a poor system configuration. In this case multiple Pega applications were running in the same Application Server instance. As such memory requirements were not the same as in the single application deployment scenario described in the installation guide.
The issue has been resolved adjusting the memory assigned to the application according to the actual load observed on the system.
