DocuSign Recipient ID Issue
I'm getting Recipient duplicate ID issue
***Moderator Edit: Lochan to tag SR Created and update SR number***
Hello!
On reviewing the SR, we see that it has been resolved. The root cause was determined to be the validation performed in a When condition present in pyValidateEnvelope activity for pyDocumentId property. The issue was resolved on removing this validation.
Hi Sri,
If you are using Pega 7.2 , you need to have the hotfix HFix-26109 installed as this fix package contains a hierarchy of abstract Pega 7 Platform classes that you can use to modify the common configuration options when you make a signature request to DocuSign.
Hello!
