In Which Scenario Linked Property will be useful
Can any one please help me to know in which case we will use Linked Property and whats the advantage?
Hi Srinivas,
A linked property is a Single Value text property that has values that are expected to match the key of an instance of a concrete class. In certain user interface and other rule configurations, linked properties can improve performance and eliminate the need to create a special-purpose activity.
You can reference properties of a linked object, retrieved by a linked property, in a rule form or expression using the syntax .LinkedPropertyName.ObjectPropertyReference.
There is a good example about linked property, please check this article https://docs-previous.pega.com/use-linked-properties-display-data-related-objects
Best Regards,
Mounika
Adding to Mounika's response, please refer the below link to know more about linked property.
https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
