Coforge Limited
Last activity: 26 Feb 2017 7:50 EST
Pega7.2 server installation issue
We are installing pega 7.2 instances in Windows server 2008 (tomcat/oracle)
It got installed fine and is working in one server but not in another server. Followed the same steps but still its failing.
PegaGUI installer failed with "unable to find prlogging.xml, some seriours error in the setup...."
So we tried a DB copy from the working server to another instance and DB copy was successful.
Server is now starting but could see loads of error saying "unable to find prlogging.xml....keyring...etc", also cannot able to open
any class instances which throws the below error
java.lang.String cannot be cast to [Ljava.lang.Object;
I searched in PDN and found that we need to add few entries in prlogging.xml but the issue here is the system cannot find the file itself.
I can able to locate the file under tomcat/webapps/prweb/web-inf/classes.
Have also verified all the user access settings, but of no use.
Am i missing something please?
DB: Oradcle 10g
OS: Windows Server 2008
WS: Tomcat 7.0
Java: jdk 1.6
Dheena
