Accenture
Last activity: 23 Aug 2018 19:06 EDT
Pega Robotics Studio (OpenSpan) - How to allow identification of element at automation run time
Is there any way in Pega robotics studio 8 (formerly openspan) using which we can provide variable name in match rule editor for dynamically selecting a web control from a group of similar web controls based on variable's value at automation run time. If yes, please suggest
Any way of giving dynamic text like %var_name which can be taken up at automation run time
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-05/1f77a272-b558-4261-964a-0a7d028c27c5.jpg?h=436c2321&itok=Ilx-4hBN)
Here is an example:
When you exit the loop if you have found the item, the web control proxy will be the DIV you are looking for. Operate on it to perform any required automation.
You cannot match dynamically like this at runtime. However, if you match using UseKeys = true, you can iterate through the matched controls using the GetClones method of the control and find the control you are looking for.
Accenture
Thanks for your reply.
Can you please give an example as to how to loop through the list of clonecollection (collection of Div elements in my case) using listLoop tool in Pega Robotics Studio 8.0 and to select one based on its inner html text value?
Here is an example:
ANZ Australian Capital Territory
SG
then how to create webControlproxy1?
![](https://accounts.pega.com/sites/default/files/pega-user-image/209/REG-209263.png?source=PUMINIT)
SG
thanks for you info, I had posted a new question as below link.
ANZ
right click and crate proxy in Item
SG
do you mean I right click "Div collection" in object explorer and create proxy?
seems there is only "Navigate to' and 'delete' can be choose when right click it.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689973000/3a78fee4-a7e7-4a05-b0f7-356e3689e691.png?itok=nN1zP2KU)
He means, right-click the blue dot (data output) on the ListLoop -> Items and you will see an option to 'Extract Proxy'
SG
got it, thank you so much.
SG
By the way, I am trying to create a "divCollection" (it contain many 'A' tag , 'Table' and 'div' tag in the webpage ) as below picture, I want loop them to capture the 'A' tag, but I can't loop any object by subjected way, could you help to check?
https://pdn.pega.com/system/files/PDN Screen.jpg
https://pdn.pega.com/system/files/ErrMsg.JPG
Also, I am trying to create another "Divcollection", i can work successfully, but only loop one time with all div code(as 3rd attachment).
SG
thanks, I had got the div Collection list.
