Pega Robotics (OpenSpan) build bymsbuild
I am trying to build Pega Robotics (OpenSpan) build outside the Studio. I tried MSbuild route and I was able to use msbuild from command line to build a local openspan project successfully. Looks like it just works out of the box – we supply the .osproj (openspan project) file as parameter, and it takes the default configuration of debug/release to build the .openspan and .manifest files.
When I try the same with solution I am getting the eroor that data at root level is incorrect
