When Setting up a REST connector what is the difference between keystore and truststore?
When you define a REST connector you have the ability to add security settings and define the keystore and truststore files. However both show classes of type Data-Admin-Security-Keystore. What would be the difference both are of the same class type? The help refers to the JKS file which is normally generated when signing the cert...
