Can Pega be hosted & deployed on Microsoft Azure Cloud?
Hi
We know that there is Pega cloud available that uses Amazon Cloud services. However, I would like to know if Pega can be hosted or deployed on any other clouds, particularly microsoft azure cloud?
SC
Yes, the Pega 7 Platform can be deployed on a Microsoft Azure customer managed cloud.
Pega Cloud is on AWS
Hello
I think it is available . Refer this available document
For a high availability environment the Pega HA guide states there are certain minimum requirements for load balancing function including session affinity, health monitoring, and also the capability for the Pega function called Quiese to interact with the load balancer to indicate that you want t take an application node offline. Is there documentation or guidance available in order to select the appropriate capabilities between the Azure Application Gateway, Azure Load Balancer, and Azure Traffic Manager in order to meet Pega's minimum requirements? Essentially can these 3 provide the necessary combination of capabilities in order to properly enable Pega's HA requirements. Or do I have to look at deploying a virtual F5 load balancer in order to accomplish it?
We have this issue also. I have read https://msdn.microsoft.com/library/azure/jj151530.aspx and this suggests creating a custom URI that returns a non 200 HTTP response that the probes monitor and can then be used to remove an app server from rotation. However how would you do that within PEGA? Especially since it would be application server specific.
Thank you for creating a new post: Pega in Azure - App Gateway configuration for HA
David - on the platform guide, it doesn't state that IIS is supported. How does Azure cloud support it? Is there some additional information available on it?
David, does it mean Pega can run on IIS ? or it's just that Pega can run on Linux VM setup on azure, could you clarify ?
Ravi
