Incessant Technologies
Last activity: 23 Jan 2017 8:03 EST
Access group clarification.
If we create application in "Implementation and Framework" layer then application explorer creates 6 access groups(3 for Framework layer and 3 for Implementation layer).
If we create an application in "Framework layer" initially and then "Implementation" is built on Framework layer then Application Express is creating only 4 Access groups(3 for Framework and 1 for Implementation). Can someone please clarify the difference between both.
Hi Manasa,
After more research with different use cases and operators came to know the exact behavior of the application creation logic to find the root cause of your scenario.
Conclusion: So the bottom line of functionality says that it will create 4 access groups(admin, author, manager and user) if you create the application with [email protected] login and it will create 2 access groups(admin and author) if you create the application with other than [email protected] login and nothing to do with the different types of the applications i.e. (Framework or Implementation or Implement and Framework layers).
Mahesh
