Access Control Policy clarifications
I have one question regarding Access control policy implementation.I implemented an Access Control Policy and one Access Control Policy condition to filter cases based on who is creating them.
The functionality works when I click on the class instances from Developer Studio , but when I open the Case Manager portal , the WorkList still shows the unfiltered work objects.
Question : do we need to add any special condition to make Access Control Policy from a user portal ?
No. What type is the Access Policy? Discover?
How did you define the Access When(s) used by your Access Policy Condition?
You said: "worklist shows unfiltered work objects".
A Worklist contains Assign-Worklist instances not cases (= work objects).
What "class instances" are you clicking on in Dev Studio?
