LeasePlan Digital
Last activity: 2 Sep 2017 13:50 EDT
Pega OOTB archival and purge.
Hi, In pega OOTB archival process, if a work object is archived and purged,data will be deleted from which tables? Is the process is same for 6.1 and 7.1.
If No, then what is the difference?
BlueRose Technologies
Purge and Archive wizard in Process Commander deletes all the work objects having status as Resolved-* from the following tables (in same order):
PR_DATA
PC_DATA_WORKATTACH
PC_LINK_ATTACHMENT
PC_HISTORY_WORK
PC_INDEX_WORKPARTY
PC_WORK
This process is same for both 6.1 and 7.1.
Virtusa
Hi Prudhvi,
Please help me in configuring Purge wizard.
Prateek
For the configuration of the Purge wizard you can look into the help provided over here for 7.1.9 version.
Kindly go through the documentation provided for the "Purge/Archive Wizard" section on left pane.
Hope this might be helpful to you.
Regards
Mahesh
Blue Rose Technologies GmbH
BE
Hello Prateek,
Please follow the article to configure archive/purge :
http://vengwindb150:8282/prhelp/procomhelpmain.htm#tools/purgearchive/aboutpurgearchivewizard.htm?Highlight=archive
Please let me know if it helps.
United Health Group
Hello Akshay,
Thanks for the help, but the URL is not opening for me.Please share the working url.
Prateek
Hi Prateek,
Its the same link as provided by Mahesh in the reply above. Here's the URL: https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
United Health Group
Thank You Lochan, I need help for configuring Purge in 6.1 sp2.
Could you please share if you have some information on that.
I need some real time configuration.
JPMorgan Chase & Company
Please refer below pdn article for 61SP2
https://community.pega.com/sites/default/files/help_v61sp2/procomhelpmain.htm
