CIBC
Last activity: 14 Dec 2016 13:54 EST
Display a Pega 6.2 case in a Pega 7.2.1 Harness using Pega 6.2 IAC - Javascript error with certain buttons
Hi, we are doing a PoC to load a Pega 6.2 case into a Pega 7.2.1 harness (we want to display the case in a Pega 7.2.1 tab in the case user portal) using Pega 6.2 IAC. We are able to display the case successfully, but some buttons, such as the Submit button, did not work because of Javascript error:
pega_desktop_domainsuffix_1819019784.js!clientlogbase_11632504602.js!pega_yui_13966702622!desktopwr…:17534 Uncaught DOMException: Blocked a frame with origin "< domain> " from accessing a cross-origin frame
It looks like by pressing the "Submit" button inside the Pega 6.2 frame, the chain of Pega JS call eventually hits a Pega 7.2 JS function, instead of what's the Pega 6.2 version.
Any idea how we can get around this problem?
It sounds like you are violating same domain origin policy. Please reference these articles.
https://pdn.pega.com/setting-gatewayurl-configuration-parameter
https://pdn.pega.com/gadget-manager-reference-pega-web-mashup
