Reverse update from 7.2.0 to 7.1.8
As per the pega update guide, we ran the update.sh to do pega update from 7.1.8 to 7.2.0. We wanted to test the reverse process in dev. When we ran a reverse .sh by updating the latest reverse xml Reverse_2016-12-12_15-23-22.xml in setupdatabase.properties file, build is failed with below below error.
Need help at the earliest. We are not able relate with the error, as we already using the latest reverse xml. Please advise
     [java] 2016-12-13 19:19:49,443 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (ternal.vtable.VirtualTableImpl) INFO    - ...Finished. Preloaded 21.9MB for 89889 rules in 16909 ms
     [java] 2016-12-13 19:19:49,443 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (   internal.mgmt.PREnvironment) INFO    - Skipping Services initialization.
     [java] 2016-12-13 19:19:49,443 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (   external.async.IStartupTask) INFO    - Awaiting for StartupTasks (parallel cache loading to finish)...
     [java] 2016-12-13 19:19:49,443 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (   external.async.IStartupTask) INFO    - All registered 'StartupTasks' (parallel cache loading) have finished.
     [java] 2016-12-13 19:19:49,956 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (nitor.internal.UsageDaemonImpl) INFO    - >>> Usage Tracking is NOT enabled on this system!
     [java] 2016-12-13 19:19:52,327 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (pcentric.RACacheAppCentricImpl) WARN    - Assembly pulse-based features disabled.
     [java] 2016-12-13 19:19:52,685 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (      etier.impl.EngineStartup) INFO    - Product type: Standard
     [java] 2016-12-13 19:19:52,766 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (      etier.impl.EngineStartup) INFO    -  Agent is disabled, immediately set node's run state to running!!!
     [java] 2016-12-13 19:19:52,792 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (      etier.impl.EngineStartup) INFO    - PegaRULES engine successfully started. TimeZone: America/Chicago AESPerfStatMode: PUSH Server: rnbww-dev4572.nam.nsroot.net System: prpc Description: rnbww-dev4572.nam.nsroot.net prpc 2016-12-13 22:54:57.359 GMT URL: [unable to determine]
     [java] 2016-12-13 19:19:52,792 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (      internal.mgmt.EngineImpl) INFO    - Embedded Environment initialization is complete.
     [java] 2016-12-13 19:19:52,958 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (l.util.InstalledHotFixMgmtImpl) INFO    - Rolling back data changes from the most recent ML
     [java] 2016-12-13 19:19:53,228 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (      external.util.RollbackML) INFO    - ML Rollback failed
     [java] 2016-12-13 19:19:53,228 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (      external.util.RollbackML) INFO    - Could not find a recent ML to rollback
     [java] 2016-12-13 19:19:53,228 [v4572.nam.nsroot.net] [  STANDARD] [                    ] (      external.util.RollbackML) ERROR   - java.lang.IllegalStateException: Could not find a recent ML to rollback
BUILD FAILED
/home/tk92768/RSM/Pega7.2.0/scripts/setupDatabase.xml:260: The following error occurred while executing this line:
/home/tk92768/RSM/Pega7.2.0/scripts/setupDatabase.xml:280: Java returned: 1
***Updated by moderator: Lochan to move post from PSC to Pega 7 Upgrade Center***
