Cognizant
Last activity: 4 Jan 2017 0:17 EST
Color coding in Report definition
I have a requirement to implement color coding in a report definition. This report definition is using grouping and we are displaying the count. The number of columns also changes dynamically hence used OOTB functionality on run report definition even on click and the results will be displayed in tree structure in OOTB section RRBody. Now we have to display the count value in different colors based on some parameters. For example we are displaying the count of resolved work items, now if the count contains any resolved-withdrawn then the count color should be green, if there are any resolved-cancelled then it should be red in such ways. Is there any way to implement this?
Hi Venkat,
PFA screen shots of an approach, see if that helps.
