Accenture
How to Apply Encryption on Class that have Data instance in it
We have a requirement to encrypt data at class level.
To implement this i have implmented Site Specific Cipher using runPega and compileAndLoad utility.
I have tested a poc using the function encryptPropertyValue which is the proof that the encryption is getting applied.
Now to apply the site specific cipher at class level, i need to check the EncryptBlob option which is available in Class Rule.
But the problem is that the Encrypt Blob option is not editable.
On doing analysis around this found that it is editable only when there is no datainstance for that class.
So in my case what approach should i take to get the encryption applied to the work object ?
P.S
Pega 7.1.7
Let me know if any further information is needed ?
Ross
