Insufficient privileges to author custom java
I am using the cloud instance from Pega SAE 7.2 course. As operator SA@TGB, I can private edit the OTB activity
CL Rule-Obj-Report-Definition
ID pzViewExportToExcel [Final, Internal]
RS Pega-Reporting:07-10-15
However, the 'Save' fails with error: "Insufficient privileges to author custom java"
what role should the operator have in order to use java step?
***Updated by moderator: Lochan to move post from PSC to Pega Academy***
Hi ,
You will not be able to save or checkin the final rules.If you really need changes for final rule that should go as HFIX.
