Last activity: 14 Nov 2016 7:13 EST
32Bit Linux Postgres9.3 - will this work as backend for PRPC721 ?
I'm looking at installing PRPC against a Postgres 9.3 DB on Linux; part of the requirement for doing this needs you to install 'pljava'.
In order to do this - you have to copy the following .so file to the Postgres 'lib' directory:
115143_Pega721\ResourceKit\PLJava\9.3\Linux\pljava.so
This is a 64bit library:
$ file pljava.so
pljava.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=f347ff880720b36dd4c28177a913d44f290320bb, not stripped
And when I try and run the 'install.sql' I get this error:
ERROR: could not load library "/usr/lib/postgresql/9.3/lib/pljava.so": /usr/lib/postgresql/9.3/lib/pljava.so: wrong ELF class: ELFCLASS64
Is there a 32bit version of the 'pljava.so' file available - or do I just have to find a 64 Bit Linux to run this ?
John
