PRPC 6.1 on Oracle 11g 64bit and Window Server 2012 64bit, tomcat 6.1
Trying to install PRPC 6.1 on 64bit Winodw Server 2012R2 with Oracle 11g + Tomcat 6.
1) Java JDK locaition C:\Program Files (x86)\Java\jdk1.6.0_14
2) Java JRE location C:\Program Files (x86)\Java\jre6
3) Tomcat 6 is is installed at C:\Program Files (x86)\Apache Software Foundation\Tomcat 6.0 and its lib folder has ojdbc6.Jar (copied from Oracle 11g 'jdbc' folder)
4) Tomcat Config\context.xml file has path of temp directory as c:\PRPC\prpctemp
5) Tomcat manager runs and \prweb.war and prsysmgmt.war and prhelp.war are deployed. but \prweb is not starting
5) After successfully installing PRPC Rules in 70-75 minutes when i try to see PRPC file in c:\PRPC\prpctemp its empty!!
6) When I try opening "http://localhost:8080/prweb/PRServlet" the result is "The requested resource (/prweb/PRServlet) is not available."PRServelt
Plzzz advise, I am totally frustrated !!
