Evonsys (Pvt) Ltd
LK
Last activity: 5 Dec 2016 7:52 EST
Dirty popup appears when we close a work item in update screen without making any changes in the case screen.
After opening a case in the update screen the user tries to close the case without making any changes to the screen.Then dirty pop up appears and display a message like “ You are about to close an open work item which has changes that have not been saved.” . I need to display dirty pop up when the screen is dirty only. Any idea?
***Moderator Edit: Vidyaranjan| Updated Categories***
We have fixed issue by changing the load behavior of the data page to At screen load. Previously its used the After screen render behavior. Thanks
