Wipro Limited
Delete the ruleset versions
Hi Team,
We have 24 rulesets in our application. We just skimmed the code from 02-01-XX,02-02-XX,02-03-XX,02-04-XX,02-05-XX to 02-07-01
Now we want to delete the versions 02-01-XX,02-02-XX,02-03-XX,02-04-XX,02-05-XX (remeber there are 99 patch versions in each) for each ruleset.
I verified the wizard tool we have and at a time only one ruleset and ruleset version can be deleted. Is there a way/wizard can delete by giving the range of ruleset versions for each ruleset.
Appreciate for the response.
Naresh K.
***10/11/2016: Updated by moderator: Lochan to add product enhancement details***
Likes (8)
Anudeep Bandaru Roberto Bertaccini sajal n KIRAN P Fergal Boden and 3 More -
Hi Naresh,
Thank you for reporting this enhancement to product. An enhancement request has been created on our internal portal. The request ID is attached to your post above (under Related Support Case Number field.)
Please refer this number to your Account Executive to track the status.
Lochan | Community Moderator | Pegasystems Inc.
Hi Naresh,
I dont think we have any separate wizard for deleting the rulesets in bulk.
Virtusa Inc
There is no separate wizard to delete multiple rulesets, at the same time,.. as you have Skimmed the Rules application is not going to refer any rules in lower rulesets versions. so is there any need for deleting the lower versions ?
Thanks.
Wipro Limited
Obviously a question indeed Veera!
As part of clean up the data, this work comes into picture. So i would not recommend to go cleaning this right?
This feature is not available however we can treat this as a genuine enhancement request.
Hi Naresh,
GDIT
Lochan,
Is this enhancement available in PRPC 7.3?
Thanks!
No, it is not available in Pega 7.3.
GDIT
Thanks! Mahesh, Any idea when it's going to be in?
