pxChangeStage
When we call pxChangeStage on an object which is in an assignment , the assignment remains open. Is this an expected behaviour?
Hi Binod
Can you elaborate it more,
If you call this Activity in a Flow using utility it wont behave like that it will complete the transaction first, but if you are calling within an Assignment then the Transaction will be incomplete and assignment will be open in that case unless and untill you come back to the respective assignment and complete the transaction.
There is a parameter to pxChangeStage activity which is used to cleanup exisitng assignments. If we don;t pass this parameter then the behavior you noticed is expected.
Let us know if this helps :)
