Lloyds Banking Group PLC
Last activity: 15 Feb 2017 11:20 EST
Unable to create Cover objects in the Implementation Layer
I have created an application by building the FW layer first with all the required Case types. Then I created the application layer on top of the FW layer inheriting all the case types. However when I try to initiate the child case types from the implementation layer I am getting error "ClassIsNotCovered "
In the case type definition the coverable child case definition is present but still the system is unable to create the covered cases.
A solution has been provided in a pdn article with SA ID: SA-11735. But still the issue persists.
Kindly help.
***Updated by Moderator: Marissa. Removed user added #helpme group tag. Apologies for confusion, shouldn't have been an end-user option; updated categories***
Hi Manash,
Can you please check and confirm if the corresponding class is inheriting from the "Cover-" class as expected by the system?
