URL for SAML SSO
How is the URL formed for SAML SSO log in?
It is defined in web.xml. OOTB there are three AuthService defined, e.g. SAMLAuth is defined as follows - the URL is http://host:port/prweb/sso. For SAMLAuth1, URL is .../prweb/sso1, etc.
<servlet>
<servlet-name>sso</servlet-name>
<display-name>sso</display-name>
<description>sso</description>
<servlet-class>com.pega.pegarules.internal.web.servlet.WebStandardBoot</servlet-class>
<init-param>
<param-name>PegaEtierClass</param-name>
<!-- COMPONENTS: This was previously com.pega.pegarules.services.HttpAPI -->
<param-value>com.pega.pegarules.session.internal.engineinterface.service.HttpAPI</param-value>
</init-param>
<init-param>
<servlet>
<init-param>
</init-param>
<init-param>
<param-name>AuthenticationType</param-name>
<param-value>PRCustom</param-value>
</init-param>
<init-param>
<param-name>StatusPage</param-name>
<param-value>/diagnostic/status.jsp</param-value>
</init-param>
<init-param>
<param-name>AuthService</param-name>
<param-value>SAMLAuth</param-value>
</init-param>
<init-param>
<param-name>RuntimeServletName</param-name>
<param-value>sso</param-value>
</init-param>
<init-param>
<param-name>SecureServletName</param-name>
</init-param>
</servlet>
Hi Kevin,
Thank you for the clarification. One more question:
I have a number of applications in Pega. How do I form the URL to point particualar URL? Or I do same URL and map the operator profiles for each application?
