How to Run Activity on User Interface?
Hi all,
I'm new to Pega and desperately need help for building an user interface.
I am trying to make a form where the end user can type in information, and with that info the system can run an 'activity' and ouput response needed to the user. What I've been trying is to:
1) Put "button" in a separate section and place it in the harness --- but when I run the harness the button seems to be disabled and nothing happens.
2) When I try to use a "check box" instead of a button it seems to be responsive. I set up an "action" for the checkbox so that when it is clicked, it will "open URL in window" and "run activity". However, when I do this it reports "failure status".
What is the correct way to connect activity to an user interface? How could I fix this situation?
Thank you very much!
***Updated by Moderator: Vidyaranjan. Removed user added #helpme and Ask the Expert tags. Apologies for confusion, shouldn't have been an end-user option***
