User Interface
What are the advantages of Dynamic UI ?please explain it in a example..
You are tasked with building a UI - and it must work in a pc-based browser and a mobile-based browser. For the mobile-based browser, you have to accomodate both portrait and landscape orientations - in the same session. This use case represents a lot of variables to try and account for, and it is unlikely you will work out a solution for all of these variables.
With dynamic UIs, you only need to focus your development effort on the "content" and Pega 7 will take care of the "presentation." Using a dynamic (responsive UI) layout means the UI will automatically adjust to the user's device. They might see three columns in a row when using a pc, two columns in a row when using a tablet in a landscape orientation, and only one column when using a smart phone.
The "advantages" of using dynamic UIs are not unique to Pega. Do a web search for "responsive UI" and you will see that this is very standard practice.
The "advantages" of using Pega 7 is the very shortened development effort it takes to produce these repsonsive UIs. When building UIs, use the dynamic layout. Then, all you need to do is specify a few parameters and Pega 7 will take care of the rest.
eddie
what is dyanamic refresh of UI .please explain with example?
Go buy something on Amazon.
Every time you add an item to, or delete an item from your cart, the total amount updates automatically - without the entire page being reloaded from the server.
eddie
