Amerprise Financial
Last activity: 20 Jul 2016 9:40 EDT
Major version skimming
We are planning to implement major version skimming and currently we have different rule sets like Implementation, Framework, Integration & organizational etc. We are looking to break down these into different tasks at the rule set level and targeting for different releases.
Questions :
- After skimming whether it goes at each rule set level or at the entire application level to have same major version. Example skimming applied only to framework rule set CaseFramework: 01-01-xx - 01-80-xx to 02-01-01 and rest others rule sets will be still in minor version like Ameriprise: 01-75-xx, AmpInt: 01-64-xx and Enterprise: 01-65-xx. Is this suggestible or works ?
- What should be skimming strategy in applying to high environments. I mean whether it should be moved as a product or same exercise of skimming should be applied in higher environments and after delete the minor version rule sets.
Please share your thoughts
Madhav
***Updated by Moderator: Lochan. Removed user added Ask the Expert tag. Apologies for confusion, shouldn't have been an end-user option***
