Last activity: 17 Jul 2017 11:15 EDT
Connect-SOAP in Pega 7.1.7 is calling an external webservice and failing with SSL handshake
Why am I getting this error trying to call an external webservice?
javax.net.ssl.SSLHandshakeException: com.ibm.jsse2.util.j: PKIX path building failed: java.security.cert.CertPathBuilderException: unable to find valid certification path to requested target
at com.ibm.jsse2.o.a(o.java:19)
at com.ibm.jsse2.SSLSocketImpl.a(SSLSocketImpl.java:689)
at com.ibm.jsse2.kb.a(kb.java:271)
at com.ibm.jsse2.kb.a(kb.java:516)
at com.ibm.jsse2.lb.a(lb.java:59)
at com.ibm.jsse2.lb.a(lb.java:274)
at com.ibm.jsse2.kb.s(kb.java:167)
at com.ibm.jsse2.kb.a(kb.java:484)
at com.ibm.jsse2.SSLSocketImpl.a(SSLSocketImpl.java:686)
at com.ibm.jsse2.SSLSocketImpl.h(SSLSocketImpl.java:704)
at com.ibm.jsse2.SSLSocketImpl.a(SSLSocketImpl.java:802)
at com.ibm.jsse2.k.write(k.java:15)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:65)
at java.io.BufferedOutputStream.write(BufferedOutputStream.java:104)
at java.io.FilterOutputStream.write(FilterOutputStream.java:80)
at com.pega.apache.axis2.transport.http.AxisRequestEntity.writeRequest(AxisRequestEntity.java:89)
at com.pega.apache.commons.httpclient.methods.EntityEnclosingMethod.writeRequestBody(EntityEnclosingMethod.java:496)
at com.pega.apache.commons.httpclient.HttpMethodBase.writeRequest(HttpMethodBase.java:1974)
at com.pega.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:994)
at com.pega.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
at com.pega.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at com.pega.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at com.pega.apache.axis2.transport.http.AbstractHTTPSender.executeMethod(AbstractHTTPSender.java:629)
at com.pega.apache.axis2.transport.http.HTTPSender.sendViaPost(HTTPSender.java:193)
at com.pega.apache.axis2.transport.http.HTTPSender.send(HTTPSender.java:75)
at com.pega.apache.axis2.transport.http.CommonsHTTPTransportSender.writeMessageWithCommons(CommonsHTTPTransportSender.java:411)
at com.pega.apache.axis2.transport.http.CommonsHTTPTransportSender.invoke(CommonsHTTPTransportSender.java:233)
at com.pega.apache.axis2.engine.AxisEngine.send(AxisEngine.java:445)
at com.pega.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:406)
at com.pega.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229)
at com.pega.apache.axis2.client.OperationClient.execute(OperationClient.java:165)
at com.pegarules.generated.activity.ra_action_invokeaxis2_ef847005fcd2daeddbdcbd42305c0be7.step14_circum0(ra_action_invokeaxis2_ef847005fcd2daeddbdcbd42305c0be7.java:3934)
at com.pegarules.generated.activity.ra_action_invokeaxis2_ef847005fcd2daeddbdcbd42305c0be7.perform(ra_action_invokeaxis2_ef847005fcd2daeddbdcbd42305c0be7.java:291)
... 106 more
Caused by:
at com.ibm.jsse2.util.h.b(h.java:104)
at com.ibm.jsse2.util.h.b(h.java:14)
at com.ibm.jsse2.util.g.a(g.java:3)
at com.ibm.jsse2.pc.a(pc.java:11)
at com.ibm.jsse2.pc.checkServerTrusted(pc.java:18)
at com.ibm.jsse2.pc.b(pc.java:56)
at com.ibm.jsse2.lb.a(lb.java:602)
... 134 more
Caused by:
at com.ibm.security.cert.PKIXCertPathBuilderImpl.buildCertPath(PKIXCertPathBuilderImpl.java:642)
at com.ibm.security.cert.PKIXCertPathBuilderImpl.engineBuild(PKIXCertPathBuilderImpl.java:357)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:258)
at com.ibm.jsse2.util.h.b(h.java:108)
***Updated by moderator: Lochan to close post***
