Asurion
Last activity: 17 Jul 2017 16:38 EDT
issue in Upgrade 7.1.8
I'm upgrading from 6.3 to 7.1.8. I ran first 2 steps migrate and upgrade script. Now when I run the migrate script for the second time to generate the rules schema object , I'm getting the below error.
/DBA01/RSM_WORKERDONOTDELETE/scripts{gpd-0b2-ea93}=>[US1CM4D]:-) cat nohup.out
Buildfile: /DBA01/RSM_WORKERDONOTDELETE/scripts/migrateSystem.xml
Setup:
[pegaropertyparser] Reading Properties from : /DBA01/RSM_WORKERDONOTDELETE/scripts/migrateSystem.properties
[mkdir] Created dir: /DBA01/RSM_WORKERDONOTDELETE/Temp/MigrateTemp-03-June-2015-14.50.07
[echo] Using temporary directory /DBA01/RSM_WORKERDONOTDELETE/Temp/MigrateTemp-03-June-2015-14.50.07
[unzip] Expanding: /DBA01/RSM_WORKERDONOTDELETE/archives/pegadbinstall-classes.zip into /DBA01/RSM_WORKERDONOTDELETE/Temp/MigrateTemp-03-June-2015-14.50.07/load
[echo] Using logging configuration from: ./config/deploylogging.properties
[propertyfile] Creating new property file: /DBA01/RSM_WORKERDONOTDELETE/Temp/MigrateTemp-03-June-2015-14.50.07/prbootstrap.properties
[pega:checkforuncommittedhotfixes] Found Uncommitted hotfixes, please commit the following hotfixes before migrating:
[pega:checkforuncommittedhotfixes] HFIX-8246
[pega:checkforuncommittedhotfixes] HFIX-7535
[pega:checkforuncommittedhotfixes] HFIX-9161
BUILD FAILED
/DBA01/RSM_WORKERDONOTDELETE/scripts/migrateSystem.xml:501: Migration cannot proceed due to uncommitted hotfixes.
It says we have uncommited hotfix , is there a way that i can force the script to run ?
***Updated by moderator: Marissa to close post***
