JP
Last activity: 18 Jul 2017 10:43 EDT
two layer of the RuleSet list
I could not understand very well the "two layers" mentioned in the below help document regarding rule-set list assembling.
According to the document all rulesets are belong to the second layer, then what is the first layer ?
Can anyone explain the "two layer" concept?
prhelp/rule-/rule-application/general.htm
Application form
Completing the Definition tab
About the RuleSets arrays
Application form
The Definition tab lists four sets of RuleSets :
- Application RuleSets
- Branches (with their associated branch RuleSets)
- Component and shared RuleSets
- Production RuleSets
The order of the entries within these lists affects the assembly of a user's RuleSet list and the operation of the rule resolution algorithm.When assembling the RuleSet list at sign-on, the system works from the top of each list down. RuleSets appear in the following order, in two layers.
- The operator's personal RuleSet, containing rules the operator has checked out, comprises the top of the second layer. (This RuleSet is not specified on the Application rule form. Operators have a personal RuleSet only if the Allow Rule Check Out? check box (on the Security tab of their Operator ID data instance) is selected.
- Branch RuleSets form the next lower group in the second layer.
- Application RuleSets form the next lower group in the second layer.
- Component and shared RuleSets, if any, form the next group of the second layer.
- Standard RuleSets provided by Pegasystems, that start with the five-character prefix "Pega-" (not the four-character prefix "Pega"), appear at the bottom of the second layer.
***Updated by moderator: Lochan to close post***
I'm having trouble understanding this question. Can you please ask it again shorter ? Thanks.
