PRPC clusters and shared storage
What shared file systems other than NFS, are supported by Pega for use by PRPC HA clusters?
If I use a Samba client on each of my Linux PRPC nodes to connect to a shared CIFS volume, will this work? Is this configuration supported by Pega?
***Updated by moderator: Lochan to close post***
Chris,
From the HA guide: https://docs-previous.pega.com/pega-718-high-availability-administration-guide
Shared Storage Application servers require fault-tolerant shared storage in order to facilitate initiated and uninitiated shutdowns. Organizations must choose a shared storage solution and will need to implement the shared storage API to integrate with PEGA 7. PEGA 7 supports shared storage using NFS or shared disk out of the box, but these solutions are not inherently fault tolerant. PEGA 7 servers require read/write access to shared storage for disk-oriented solutions.
In theory CIFS should work just like NFS but we have never tested that - whether we want to officially support CIFS is a decision from product management. You may also want to implement a custom solution, similar to this example: https://community.pega.com/integration/creating-a-custom-passivation-method
