Last activity: 10 Sep 2015 12:46 EDT
( Pega V 7.1.8) java.lang.ClassNotFoundException: Failed to load class com.pega.pegarules.session.internal.authorization.ContextMapDiagCallback
I am having 2 Clusters, each cluster has 2 managed servers. I am using proxy servlet in a different managed server which is not there in these 2 clusters to perform load balancing.
Whenever the request switches from one system to another, we need to replicate the sessions, for that I have configured the weblogic.xml i.e
<session-descriptor>
<persistent-store-type>replicated</persistent-store-type>
</session-descriptor>
When I deployed the application into clusters, the managed servers in cluster 2 throw this error
<Aug 27, 2015 2:29:28 AM IST> <Error> <Cluster> <L-MAA-25004251> <ms4> <[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <> <1440622768965> <BEA-000126> <All session objects should be serializable to replicate. Check the objects in the session. Failed to replicate a non-serializable object.
java.rmi.UnmarshalException: error unmarshalling arguments; nested exception is:
at weblogic.rjvm.ResponseImpl.unmarshalReturn(ResponseImpl.java:237)
at weblogic.rmi.internal.BasicRemoteRef.invoke(BasicRemoteRef.java:300)
at weblogic.cluster.replication.ReplicationManager_1211_WLStub.create(Unknown Source)
at sun.reflect.GeneratedMethodAccessor122.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at weblogic.cluster.replication.SecureReplicationInvocationHandler$ReplicationServicesInvocationAction.run(SecureReplicationInvocationHandler.java:194)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.cluster.replication.SecureReplicationInvocationHandler.invoke(SecureReplicationInvocationHandler.java:164)
at $Proxy77.create(Unknown Source)
at weblogic.cluster.replication.ReplicationManager.trySecondary(ReplicationManager.java:937)
at weblogic.cluster.replication.ReplicationManager.createSecondary(ReplicationManager.java:890)
at weblogic.cluster.replication.ReplicationManager.getPrimary(ReplicationManager.java:866)
at weblogic.cluster.replication.ReplicationManager.lookup(ReplicationManager.java:428)
at weblogic.servlet.internal.session.ReplicatedSessionContext.lookupSession(ReplicatedSessionContext.java:416)
at weblogic.servlet.internal.session.ReplicatedSessionContext.getSessionInternal(ReplicatedSessionContext.java:258)
at weblogic.servlet.internal.session.ReplicatedSessionContext.getSessionInternal(ReplicatedSessionContext.java:250)
at weblogic.servlet.internal.ServletRequestImpl$SessionHelper.getValidSession(ServletRequestImpl.java:3102)
at weblogic.servlet.internal.ServletRequestImpl$SessionHelper.getSessionInternal(ServletRequestImpl.java:2625)
at weblogic.servlet.internal.ServletRequestImpl$SessionHelper.getSession(ServletRequestImpl.java:2592)
at weblogic.servlet.internal.ServletRequestImpl.getSession(ServletRequestImpl.java:1352)
at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2100)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2089)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2074)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1513)
at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:254)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Caused By: java.lang.ClassNotFoundException: Failed to load class com.pega.pegarules.session.internal.authorization.ContextMapDiagCallback
at weblogic.rmi.utils.WLRMIClassLoaderDelegate.loadClass(WLRMIClassLoaderDelegate.java:208)
at weblogic.rmi.utils.WLRMIClassLoaderDelegate.loadClass(WLRMIClassLoaderDelegate.java:135)
at weblogic.rmi.utils.Utilities.loadClass(Utilities.java:305)
at weblogic.rjvm.MsgAbbrevInputStream.resolveClass(MsgAbbrevInputStream.java:436)
at weblogic.utils.io.ChunkedObjectInputStream$NestedObjectInputStream.resolveClass(ChunkedObjectInputStream.java:268)
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1574)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1495)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1731)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1328)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1946)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1870)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1752)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:350)
at java.util.Hashtable.readObject(Hashtable.java:844)
at sun.reflect.GeneratedMethodAccessor86.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:974)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1848)
at weblogic.servlet.internal.session.ReplicatedSessionData.readExternal(ReplicatedSessionData.java:154)
at java.io.ObjectInputStream.readExternalData(ObjectInputStream.java:1791)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1750)
at weblogic.utils.io.ChunkedObjectInputStream.readObject(ChunkedObjectInputStream.java:208)
at weblogic.rjvm.MsgAbbrevInputStream.readObject(MsgAbbrevInputStream.java:599)
at weblogic.utils.io.ChunkedObjectInputStream.readObject(ChunkedObjectInputStream.java:204)
at weblogic.cluster.replication.ReplicationManager_WLSkel.invoke(Unknown Source)
at weblogic.rmi.internal.BasicServerRef.invoke(BasicServerRef.java:696)
at weblogic.rmi.internal.BasicServerRef$1.run(BasicServerRef.java:521)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:363)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:146)
at weblogic.rmi.internal.BasicServerRef.handleRequest(BasicServerRef.java:516)
at weblogic.rmi.internal.wls.WLSExecuteRequest.run(WLSExecuteRequest.java:119)
####<Aug 27, 2015 2:29:28 AM IST> <Error> <Cluster> <L-MAA-25004251> <ms4> <[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <> <e84bae63a4864aa7:1266100f:14f6bc54e80:-8000-000000000000005a> <1440622768993> <BEA-000126> <All session objects should be serializable to replicate. Check the objects in the session. Failed to replicate a non-serializable object.
at weblogic.cluster.replication.ReplicationManager.updateSecondary(ReplicationManager.java:704)
at weblogic.servlet.internal.session.ReplicatedSessionData.syncSession(ReplicatedSessionData.java:630)
at weblogic.servlet.internal.session.ReplicatedSessionContext.sync(ReplicatedSessionContext.java:94)
at weblogic.servlet.internal.ServletRequestImpl$SessionHelper.syncSession(ServletRequestImpl.java:3066)
at weblogic.servlet.internal.ServletRequestImpl$SessionHelper.syncSession(ServletRequestImpl.java:3041)
at weblogic.servlet.internal.ServletResponseImpl$1.run(ServletResponseImpl.java:1523)
this happens when a serializable object references a non-serializable object.
Anything I am doing wrong? could anyone help me with this.
Pega V 7.1.8
