TCS
Last activity: 26 Oct 2015 2:23 EDT
hi,needed to open the workobject in review mode.How to achieve it with Open method
I have attached the business requirement for this(Question.txt).
SectionRule snapshot-The section we included to open the WO in review Mode.
Error snapshot-We are getting this error on F5 or refresh.
Please do reply for this.
Thanks.
FR
Which PRPC version are you using.
TCS
I am using PRPC 7.1.7.
FR
Well if you already have the report finding the WorkObjects for you, then you just need to use the Obj-Open-By-Handle method (I let you choose the page name) and use the SECTION used on the REVIEW harness to display the details of the case.
TCS
In attachment I have mention that ,
I have tried using Obj-Open-By-Handle option in portal,but I was not able to plugin the login to determine the WO ID at runtime.
FR
All right,
Which login are you using ? You having an SSO or something ?
TCS
We are using SSO login.
FR
Ok,
In theory, your SSO login should somehow generate the OeratorID page containing all the needed information for your report.
TCS
Hi marc,
There was a typoerror In Login ,it should be a logic .So there is no relation between the login type.I have updated the question.Please can you look into it now.
Thanks.
