Wipro
Last activity: 20 Dec 2016 5:27 EST
Code Review using Custom fields
Hi, I have a requirement to do code review in Pega and generate a report on what % of code is being reviewed. I thought of using custom fields in Pega rule form (under history tab of any rule) and add a code review property and update it when ever code re view is done and generate a report from it. but it is final rule and I cant do any modifications to it. Also its a page group and static as well. lets say on 11/01 i did a code review and add a comment and on 12/01 if I have to d again, Pega will override the property value and I loose the previous changes. What is the best way of doing Code review in pega and how can I run reports from it?
Sri.
Hi Sridhar,
I'm not sure exactly what you mean. Are you just trying to track that a code review was done for a given rule? Trying to track what percentage of the rule was reviewed seems incredibly error prone/open for interpretation. Are you limiting this to activities and data transforms? Do you base percentage on the number of steps (i.e. I've reviewed the first 3 steps of a 10 step activity, I've done 30%)? How does something like a Java step factor into all of this? For UI rules, how do you judge the review of the various controls and includes, and the values passed into them?
Does the tracking have to be associated directly with the ruleform or can you possibly create an activity that you run against a given rule to add an entry to a database table with the rule, the date/time, and whatever notes you want? Then you can report off that table. Or if you require the review before you all rule check in, you could put the review notes in there? That would be viewable from the history tab.
Mike
