PageList should be required field
I have a "Pagelist" property(Repeating Grid) on a form, through a source values are being set to that Pagelist, when user submitting form it shouldn't be null.
how can i make Pagelist as mandatory field.
Suresh Chella
Hi Santanu,
Have tried, i cant see 'star mark' .
FYI: am using PEGA 7.1.6
Suresh Chella
Thanks for immediate reply
i think its a row editing, in my requirement , on click of a button values are being set to Pagelist. So system should check Pagelist contains atleast a record before submitting form.
Anyway i will try and let you know
Suresh
Hi Santanu,
Am unable to see red mark though i made field as required .
Can you suggest any alternative method
Suresh
Hi
It could be a CSS specific problem. Can you try login with Administrator@pega.com and check the said behavior by doing private check out of the section pxRowEditing and making the field pyCommonName mandatory.
Ideally you should see the red exclamation mark against the field .Please share the result
Hi Suresh,
When you say 'required' here - do you intend that the PageList has 'at least one entry in it?' - I'm not clear in my own head what 'required' means in terms of non-scalar properties.....(does an 'empty' PageList count as being 'filled-in' ?)
Cheers
John
Hi Jhon,
Yes, we should check that Pagelist contains atleast a record.
thanks
Suresh
Hi Suresh,
You can do this easily in Post Activity of the flow action, where you check for length of page list is greater than 0. Then Set Error Message on Page if length is 0. That way you will be able to force the user to add a row.
Prasad
Hi Prasad,
i have solved this issue with the same model earlier, but thanks for responding
