How to display all assignments from different application in a single portal?
The requirement is to create a new Portal on which they want to list all assignments for a user from different applications. For example, if you have access to Application 1 and application 2, create another application – Application 3. This application Portal will list the assignments for you from application 1 and application 2.
Hi Ankan,
Explore Federated Case Management, it is used for such requirements.
Refer: https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
