Accenture
Last activity: 11 Jan 2016 22:09 EST
Loading Data Page using an activity
I want to use an auto-complete field to show a list of employees filtered by characters that user types in the field. The design that I have in mind is that I will link this field with a data page which will be of Code-Pega-List type and will be defined as follows
In order to implement this I following design in mind
1. The data is sourced from LDAP which is accessible through Authentication Service (Data-Admin-Authservice). I am not sure if there is a "connector" available to get data from an Authentication Service.
2. This means that I must use a function to run this service and get the data. I guess I will have to use a "Load Activity" to run this function which I don't want to use as Pega doesn't recommend it.
I will appreciate if someone can look at this and let me know if this is a good design or if there is a better alternate way to achieve same
Best Regards
