Getting HTTP 404 error launching Pega 7.2.0 Personal Edition
Hi ,
I installed Pega PRC 7.2 -PE in PC for 2 days back, it was installed successfully and was able to import RAR file that was taken from 7.1.9, couple of rules were modified as well ,
but now it is giving 404 error when i tried it. Looks like pega DB tables, classes are not loaded successfully.
Please help me in how can we resolve it.
Attached the console data after start up.
looks like you have database connection issue - maybe your connection pool is too small. Can you check your tomcat context.xml (under conf directory normally) and use the following three attributes for the datasource connection pool definition if your current connection pool sizes are too small.
maxTotal="100"
maxIdle="30"
maxWait="10000"
Hi Kevin,
Still the issue is persisted ,despite of modified the following config elements.
<Resource name="jdbc/PegaRULES"
auth="Container"
type="javax.sql.DataSource"
maxActive="300"
maxIdle="50"
maxWait="10000"
driverClassName="org.postgresql.Driver"
url="jdbc:postgresql://localhost:5432/pega"
username="pega"
password="pega"/>
<Environment name="url/initialization/explicittempdir" value="C:\PRPCPersonalEdition\temp" type="java.lang.String" />
</Context>
that is not what I suggested maxActive needs to be maxTotal. Can you try that first before we go on to the next steps?
Still issue is persisted after modified the config elements.
Here is the start up console .
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option PermSize=64m; support was removed in 8.0
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=384m; support was removed in 8.0
26-Feb-2016 07:09:44.075 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.28
26-Feb-2016 07:09:44.075 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Oct 7 2015 18:25:21 UTC
26-Feb-2016 07:09:44.075 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: Proprietary information hidden
26-Feb-2016 07:09:44.075 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 10
26-Feb-2016 07:09:44.075 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
26-Feb-2016 07:09:44.075 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\PRPCPersonalEdition\jre1.8.0_66
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_66-b18
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\PRPCPersonalEdition\tomcat
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\PRPCPersonalEdition\tomcat
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms1024m
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx1024m
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:PermSize=64m
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:MaxPermSize=384m
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\PRPCPersonalEdition\scripts\..\tomcat\conf\logging.properties
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -DPETomcatHTTPPort=8080
26-Feb-2016 07:09:44.091 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\PRPCPersonalEdition\scripts\..\tomcat\endorsed
26-Feb-2016 07:09:44.106 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\PRPCPersonalEdition\scripts\..\tomcat
26-Feb-2016 07:09:44.106 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\PRPCPersonalEdition\scripts\..\tomcat
26-Feb-2016 07:09:44.106 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\PRPCPersonalEdition\scripts\..\tomcat\temp
26-Feb-2016 07:09:44.106 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\PRPCPersonalEdition\jre1.8.0_66\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\PRPCPersonalEdition\jre1.8.0_66\bin;C:\PRPCPersonalEdition\jre1.8.0_66\bin\server;"C:\PRPCPersonalEdition\scripts\..\pgsql\bin";C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;.
26-Feb-2016 07:09:44.309 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
26-Feb-2016 07:09:44.403 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
26-Feb-2016 07:09:44.403 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-9009"]
26-Feb-2016 07:09:44.403 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 815 ms
26-Feb-2016 07:09:44.450 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
26-Feb-2016 07:09:44.450 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.28
26-Feb-2016 07:09:44.505 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\PRPCPersonalEdition\tomcat\webapps\prhelp.war
26-Feb-2016 07:09:44.984 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
26-Feb-2016 07:09:45.015 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
26-Feb-2016 07:09:45.140 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\PRPCPersonalEdition\tomcat\webapps\prhelp.war has finished in 635 ms
26-Feb-2016 07:09:45.140 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\PRPCPersonalEdition\tomcat\webapps\prsysmgmt.war
26-Feb-2016 07:09:46.593 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
26-Feb-2016 07:09:46.718 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
SMA: Using configuration file: C:\PRPCPersonalEdition\tomcat\work\Catalina\localhost\prsysmgmt\Nodes.xml
26-Feb-2016 07:09:47.140 INFO [localhost-startStop-1] com.opensymphony.xwork2.config.providers.XmlConfigurationProvider.info Parsing configuration file [struts-default.xml]
26-Feb-2016 07:09:47.234 INFO [localhost-startStop-1] com.opensymphony.xwork2.config.providers.XmlConfigurationProvider.info Unable to locate configuration files of the name struts-plugin.xml, skipping
26-Feb-2016 07:09:47.234 INFO [localhost-startStop-1] com.opensymphony.xwork2.config.providers.XmlConfigurationProvider.info Parsing configuration file [struts-plugin.xml]
26-Feb-2016 07:09:47.265 INFO [localhost-startStop-1] com.opensymphony.xwork2.config.providers.XmlConfigurationProvider.info Parsing configuration file [struts.xml]
26-Feb-2016 07:09:47.265 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.ObjectFactory)
26-Feb-2016 07:09:47.265 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.factory.ActionFactory)
26-Feb-2016 07:09:47.265 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.factory.ResultFactory)
26-Feb-2016 07:09:47.281 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.factory.ConverterFactory)
26-Feb-2016 07:09:47.281 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.factory.InterceptorFactory)
26-Feb-2016 07:09:47.281 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.factory.ValidatorFactory)
26-Feb-2016 07:09:47.281 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.factory.UnknownHandlerFactory)
26-Feb-2016 07:09:47.281 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.FileManagerFactory)
26-Feb-2016 07:09:47.294 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.XWorkConverter)
26-Feb-2016 07:09:47.296 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.CollectionConverter)
26-Feb-2016 07:09:47.298 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.ArrayConverter)
26-Feb-2016 07:09:47.300 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.DateConverter)
26-Feb-2016 07:09:47.302 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.NumberConverter)
26-Feb-2016 07:09:47.304 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.StringConverter)
26-Feb-2016 07:09:47.307 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.ConversionPropertiesProcessor)
26-Feb-2016 07:09:47.309 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.ConversionFileProcessor)
26-Feb-2016 07:09:47.312 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.ConversionAnnotationProcessor)
26-Feb-2016 07:09:47.313 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.TypeConverterCreator)
26-Feb-2016 07:09:47.315 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.TypeConverterHolder)
26-Feb-2016 07:09:47.317 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.TextProvider)
26-Feb-2016 07:09:47.319 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.LocaleProvider)
26-Feb-2016 07:09:47.321 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.ActionProxyFactory)
26-Feb-2016 07:09:47.324 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.conversion.ObjectTypeDeterminer)
26-Feb-2016 07:09:47.326 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (org.apache.struts2.dispatcher.mapper.ActionMapper)
26-Feb-2016 07:09:47.328 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (jakarta) for (org.apache.struts2.dispatcher.multipart.MultiPartRequest)
26-Feb-2016 07:09:47.330 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (org.apache.struts2.views.freemarker.FreemarkerManager)
26-Feb-2016 07:09:47.335 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (org.apache.struts2.components.UrlRenderer)
26-Feb-2016 07:09:47.336 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.validator.ActionValidatorManager)
26-Feb-2016 07:09:47.337 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.util.ValueStackFactory)
26-Feb-2016 07:09:47.339 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.util.reflection.ReflectionProvider)
26-Feb-2016 07:09:47.341 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.util.reflection.ReflectionContextFactory)
26-Feb-2016 07:09:47.343 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.util.PatternMatcher)
26-Feb-2016 07:09:47.346 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (org.apache.struts2.dispatcher.StaticContentLoader)
26-Feb-2016 07:09:47.348 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.UnknownHandlerManager)
26-Feb-2016 07:09:47.350 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (org.apache.struts2.views.util.UrlHelper)
26-Feb-2016 07:09:47.352 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.util.TextParser)
26-Feb-2016 07:09:47.354 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (org.apache.struts2.dispatcher.DispatcherErrorHandler)
26-Feb-2016 07:09:47.356 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.security.ExcludedPatternsChecker)
26-Feb-2016 07:09:47.361 INFO [localhost-startStop-1] org.apache.struts2.config.AbstractBeanSelectionProvider.info Choosing bean (struts) for (com.opensymphony.xwork2.security.AcceptedPatternsChecker)
26-Feb-2016 07:09:47.367 INFO [localhost-startStop-1] org.apache.struts2.config.DefaultBeanSelectionProvider.info Loading global messages from [ApplicationResources]
26-Feb-2016 07:09:47.923 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\PRPCPersonalEdition\tomcat\webapps\prsysmgmt.war has finished in 2,783 ms
26-Feb-2016 07:09:47.939 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\PRPCPersonalEdition\tomcat\webapps\prweb.war
26-Feb-2016 07:09:48.283 INFO [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PRFileStore Ignoring unknown property: value of "Database-based File Access" for "description" property
26-Feb-2016 07:09:48.283 INFO [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = AdminPegaRULES Ignoring unknown property: value of "PegaRULES Admin datasource" for "description" property
26-Feb-2016 07:09:48.283 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
26-Feb-2016 07:09:48.330 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
26-Feb-2016 07:09:48.564 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Loading bootstrap properties from /prbootstrap.properties
26-Feb-2016 07:09:48.564 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
26-Feb-2016 07:09:48.564 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
26-Feb-2016 07:09:48.564 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
26-Feb-2016 07:09:48.580 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
26-Feb-2016 07:09:48.580 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Bootstrap datatables schema: null
26-Feb-2016 07:09:48.658 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Unable to connect to database. Will only use properties from file.
java.sql.SQLException: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2293)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2038)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1532)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapPropertiesFromDB(PRBootstrapDataSource.java:669)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapPropertiesFromDB(PRBootstrapDataSource.java:652)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapProperties(PRBootstrapDataSource.java:629)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapProperties(PRBootstrapDataSource.java:623)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.<clinit>(PRBootstrap.java:119)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.checkForStartup(AppServerBridgeToPega.java:117)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4738)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5181)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:945)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1798)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.postgresql.util.PSQLException: FATAL: the database system is starting up
at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:427)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:203)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:65)
at org.postgresql.jdbc.PgConnection.<init>(PgConnection.java:159)
at org.postgresql.Driver.makeConnection(Driver.java:415)
at org.postgresql.Driver.connect(Driver.java:283)
at org.apache.tomcat.dbcp.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.tomcat.dbcp.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:255)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2303)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2289)
... 28 more
26-Feb-2016 07:09:48.673 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Archive version [0]
26-Feb-2016 07:09:48.673 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine schema defined in allclasses: null
26-Feb-2016 07:09:48.689 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
26-Feb-2016 07:09:48.696 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
26-Feb-2016 07:09:48.697 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine classes schema: null
26-Feb-2016 07:09:48.699 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Assembled classes schema: null
26-Feb-2016 07:09:48.701 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
26-Feb-2016 07:09:48.748 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
26-Feb-2016 07:09:48.751 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:
26-Feb-2016 07:09:48.799 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. PRMiniLoader - unable to load classes from the database: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
C:\PRPCPersonalEdition\tomcat\webapps\prweb\WEB-INF\lib\boot\prbootphase2.jar (The system cannot find the path specified)
Perhaps executing with a non-standard classpath (e.g. JUnit tests)?
at com.pega.pegarules.internal.bootstrap.PRBootstrap.printConfiguration(PRBootstrap.java:772)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:665)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
... 21 more
26-Feb-2016 07:09:48.932 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap.
============ PegaRULES Bootstrap Configuration ============
Date: Fri Feb 26 07:09:48 IST 2016
Java Version: Oracle Corporation 1.8.0_66
Configuration: file:/C:/PRPCPersonalEdition/tomcat/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode:
Unable to use given database configuration
Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
Unable to load phase 2 bootstrap class: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
26-Feb-2016 07:09:48.938 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:388)
at java.lang.ClassLoader.loadClass(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.loadPhase2BootstrapClass(PRBootstrap.java:720)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:662)
26-Feb-2016 07:09:48.945 SEVERE [localhost-startStop-1] com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega. Problem during method invocation (contextInitialized)
java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.web.servlet.WebAppLifeCycleListener
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplementationOf(PRBootstrap.java:208)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PRBootstrap.java:324)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(PRBootstrap.java:304)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:409)
26-Feb-2016 07:09:48.951 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
26-Feb-2016 07:09:48.954 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/prweb] startup failed due to previous errors
26-Feb-2016 07:09:48.959 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
26-Feb-2016 07:09:49.003 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
26-Feb-2016 07:09:49.004 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:
26-Feb-2016 07:09:49.054 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. PRMiniLoader - unable to load classes from the database: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextDestroyed(WebAppLifeCycleListenerBoot.java:67)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4785)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5404)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:232)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:160)
... 22 more
26-Feb-2016 07:09:49.184 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap.
Date: Fri Feb 26 07:09:49 IST 2016
Pega-EngineCode:
26-Feb-2016 07:09:49.191 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Error initializing PRAppLoader
26-Feb-2016 07:09:49.197 SEVERE [localhost-startStop-1] com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega. Problem during method invocation (contextDestroyed)
26-Feb-2016 07:09:49.334 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\PRPCPersonalEdition\tomcat\webapps\prweb.war has finished in 1,394 ms
26-Feb-2016 07:09:49.337 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\docs
26-Feb-2016 07:09:49.531 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
26-Feb-2016 07:09:49.531 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
26-Feb-2016 07:09:49.546 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\docs has finished in 209 ms
26-Feb-2016 07:09:49.546 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\examples
26-Feb-2016 07:09:51.922 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
26-Feb-2016 07:09:52.062 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
26-Feb-2016 07:09:52.234 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\examples has finished in 2,688 ms
26-Feb-2016 07:09:52.234 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\host-manager
26-Feb-2016 07:09:52.421 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
26-Feb-2016 07:09:52.421 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
26-Feb-2016 07:09:52.437 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\host-manager has finished in 203 ms
26-Feb-2016 07:09:52.437 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\manager
26-Feb-2016 07:09:52.640 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
26-Feb-2016 07:09:52.671 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
26-Feb-2016 07:09:52.671 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\manager has finished in 234 ms
26-Feb-2016 07:09:52.671 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\ROOT
26-Feb-2016 07:09:52.797 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
26-Feb-2016 07:09:52.797 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
26-Feb-2016 07:09:52.812 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\ROOT has finished in 141 ms
26-Feb-2016 07:09:52.828 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
26-Feb-2016 07:09:52.875 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-9009"]
26-Feb-2016 07:09:52.875 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 8461 ms
looks like db may not be ready when apache starting up. Can you connect to the db using pgadmin tool?
nothing interesting there. I was hoping to see if the db did not start up correctly. Can you actually login using pgadmin3 tool?
The issue is being occurred when tomcat is start up for the first time ,so if we shutdown it then start it again then it's working fine.
The DB connection is being established only after start up the tomcat server but not prior to that as tied to login using pgadminIII tool before start up the server but an error has been thrown as "Server Doesn't listen".
Attached the start up logs when problem occurs and not occurred as well.
so this confirms my suspicion: db was not ready yet when the tomcat is starting up. Not sure why, both of your logs look the same to me, did you attach the same logs? In any case, this is personal edition, if I were you, I would not want to spend too much time on debugging, instead, simply reinstall the PE again - it takes only 15 mins.
Still getting the same issue after reinstall the PE again.
Presently I'm not worrying about it since it's been working for the second time.
thanks for the follow up, if you do not care anymore, can you please close the thread?
