Capgemini India Pvt. Ltd.
Last activity: 7 Apr 2017 11:46 EDT
I am new to the pega and have learning/practising through the online. When I decided to install it locally(Pega 7) it's causing the problem.
After finishing all the steps, it starts installing the pega 7 in my system but spending 2 minutes of time during installation suddenly throws below error:
BUILD FAILED
E:\114898_PE719\pegaGuiInstallerTemp16\build.xml:192: The following error occurred while executing this line:
E:\114898_PE719\pegaGuiInstallerTemp16\build.xml:75: exec returned: 1
Total time: 1 minute 35 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:89)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
... 2 more
BUILD FAILED
... 2 more
--- Nested Exception ---
I am unable figure it out the cause of problem. Please help?
Your help is appreciated.
PEG
Please refer https://mesh.pega.com/message/200906
I have installed java 1.7 and have setup ANT_HOME but when installing Pega 7, I am getting below error:
[exec] Result: 1
BUILD FAILED
E:\114898_PE719\pegaGuiInstallerTemp18\build.xml:191: The following error occurred while executing this line:
E:\114898_PE719\pegaGuiInstallerTemp18\build.xml:75: exec returned: 1
Total time: 1 minute 59 seconds
... 2 more
Please help with this.
Can you please share entries from setenv.bat file ( can be found under Tomcat/bin)
Here is what the 'setenv.bat' conatains:
rem Change -Xmx value based on available physical memory
rem -- This is for JMX support
rem
set JRE_HOME=C:\PRPCPersonalEdition\jre1.7.0_71
set JAVA_OPTS=-Xms1024m -Xmx1024m -XX:PermSize=64m -XX:MaxPermSize=384m
Hi Vivek,
In addition to what Phil said, kindly take backup of setenv.bat and replace its content with following:
________________________________________________________________________________
set JAVA_OPTS=-Xms768m -Xmx899m -XX:PermSize=128m -XX:MaxPermSize=256m -Djava.awt.headless=true
rem set JAVA_OPTS=-Xms512m -Xmx1024m -XX:PermSize=64m -XX:MaxPermSize=256m -Djava.awt.headless=true -Dcom.pega.pegarules.bootstrap.ignorejndi=true
rem End of lines added by PegaRULES Installation Process
I processed as was suggested by you and tried reinstalling it again. It's failed gain with below error:
[exec] Result: 1
BUILD FAILED
E:\114898_PE719\pegaGuiInstallerTemp20\build.xml:157: Unable to connect to database within 15 seconds.
Total time: 1 minute 27 seconds
... 2 more
Hi Vivek,
As a solution, can you run the process again after deleting the files from the folder(PRPCPersonalEdition/scripts/SetupDBandUser) and also temp files.
I have tried deleting C:\PRPCPersonalEdition\scripts\SetupDBandUser.sql and temp files first time but if failed and got some error. I have one more friend who is trying to install the pega personal edition. So I checked with the friend. He was suggested by PDN developers to delete the file from above path. Before you replied I had already tried the workaround. Later I saw your reply so followed the same workaround again. Installation failed again with below error:
[exec] Result: 1
BUILD FAILED
E:\114898_PE719\pegaGuiInstallerTemp22\build.xml:191: The following error occurred while executing this line:
E:\114898_PE719\pegaGuiInstallerTemp22\build.xml:75: exec returned: 1
Total time: 1 minute 20 seconds
... 2 more
[exec] Result: 1
BUILD FAILED
... 2 more
Hi Arvind,
Can you please help me with below error:
[exec] Result: 1
BUILD FAILED
... 2 more
Hi Vivek,
Can you please let us know the windows version where you are installing PE?
Hi Arvind,
It's Windows 7 sp1 64 bit
[exec] Result: 1
BUILD FAILED
... 2 more
PEG
Did you set JAVA_HOME and Path environment variables? If not , please set and give it a try.
yes i tried it but after this also its failing with same error
Updated: 29 Feb 2016 16:04 EST
Do you have a JAVA_HOME set for the OS? You can run "set" from command prompt to check:
C:\Users\shanp>set
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\shanp\AppData\Roaming
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=LSHANPW8
ComSpec=C:\Windows\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Users\shanp
JAVA_HOME=C:\Java\jdk1.7.0_79\
NUMBER_OF_PROCESSORS=8
OS=Windows_NT
If yours shows a JDK 1.8, install a JDK 1.7 and point JAVA_HOME to that one, and try again...
I checked it and found version 1.7.0
