United health group
Last activity: 14 Mar 2016 1:02 EDT
Can some one explain me the use of Normalise parse rules
Citicorp Services India Private Limited
Hi Pavani,
Will this PDN link help https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm
Gowrishankar.
United health group
Thank you Gowri.
I read that link earlier but I understood it as similar to Edit validate rule for changing format of text .
Could you please explain with some examples.
Use case example
- Case should be created from an external file using listener
File content format
- one of the file tag could be a variable defined pattern example (Date, Dated, Dt.) to map to date property.
Method
- using activity method 'Text-Normalize' we will map the value to date property.
United health group
Hi Phani so as per the example we have a value in file as example -"24-05-2016" then in activity text normalize will set it to a property?
Accenture
SG
hi Phani,
Could you please explain this statement and how it can be achieved? This is present in Pega Help
For example, the original text string may contain a date or amount in any one of a variety of formats. If the desired date format is YYYY-MM-DD (for example 2009-10-12), parse normalize rules can search for dates in other formats and replace the value with the normalized format.
United health group
Yea can some one explain with screen shots how to achieve it
United health group
Phani can you also explain me in which scenarios we do this parse normalize or can u explain me in your example y are you normalizing it.
Accenture
SG
So Phani,
Here how we are formatting the date (to YYYY-MM-DD) we are just replacing with -TXDATE-
United health group
Thank you Phani, Its clear now.
screenshots attached from our legacy application ...
Parse Normalize rule
Normalize rule reference
