Last activity: 9 Mar 2016 16:10 EST
Can't reference a property from a parameterized Data Page
This Property Reference does not work for this parameterized Data Page.
D_GetTotOpenServiceCount[MemberID:pyWorkPage.MemberID,ContractID:pyWorkPage.Policy.ContractID].pxResultCount
It throws an error.
D_GetTotOpenServiceCount[MemberID:pyWorkPage.MemberID,ContractID:pyWorkPage.Policy.ContractID].pxResultCount doesn't exist or is not a valid entry for this ruleset and its prerequisites
pxResultCount is an OOTB property under Code-Pega-List class and it should exist and available.
(D_GetTotOpenServiceCount is Code-Pega-List type)
When i tried to reference another OOTB property, it saves fine.
* D_GetTotOpenServiceCount[MemberID:pyWorkPage.MemberID,ContractID:pyWorkPage.Policy.ContractID].ContactId
I am doing a property reference from a Dynamic Layout from a section.
Attached some more details. Appreciate any insights.
Will
going back to basics, I'd probably:
- Define a transient property on work
- have a list data page sourced from report
- create a declare expression for property from step 1
- define the expression as length of page list on data page
- have change tracking on the property as when used if no value present
Its unfortunately midnight here so I can't validate that works; I'll check in the morning.
Hey Will, does this still occur if you save CPMDisplayServiceItems into 01-14-02; this is where the Data Page is defined according to the screenshots?
Alternately does the displayed configuration look the same in 01-14-01 for D_GetToOpenServiceCount
Hey Will,
Can you post screenshots of both
- Pages and Classes for the Section.
- Parameter tab for the Data Page.
Cheers,
Joel
Also tried to create a new TotalCount property and this did not work.
Updated: 8 Mar 2016 19:23 EST
Ok, So I recreated in my PE on 7.1.9.
The issue is that it wont recognize that as a page, you can force it to save by listing the fully qualified page, however this is then not treated as a data page on render (so you get blank, or even a corrupted section causing the rest of the page to not render.)
To get around this, I'd recommend either using the data page as the context for a section include, then have a section on Code-Pega-List that displays the count
or
use this data page as a source for a property on pyWorkPage
i.e. pyWorkPage.TotalOpenServiceCount, as a property sourced automatically from the data page, then use pyWorkPage.TotalOpenServiceCount.pxResultCount
Thanks Joel. The section method seems to work .. just validating now.
However, using a property with a data source as DP seems to throw the same error.
This is the property I created:
This is the DP:
I'm referencing the new property in the Dynamic Layout:
When I save the rule, it throws the same error. Very Strange. Seems a right configuration. Did you make this work in your test application?
This is the DP:
Oh hold on Will, Sorry.
The Data Page should be a Page structure of Code-Pega-List, or a List structure of what you're reporting on (Which will in turn create a page of Code-Pega-List).
Thanks Joel again. This is my latest configurations. I am trying to show the result count but it shows up empty.
This has been quite a struggle. Can I go back and as you a basic question? I simply want to show the total result count on UI from a Report Definition using Data Page. How would you accomplish this?
No problem Joel. Appreciate your help. I will also try your suggestion later this afternoon and let you know.
Hey Will,
Can you change the control to formatted text. pxResultCount has the security attribute: "Cannot be included as input field" which may impact.
Cheers,
Joel
