CGI
Last activity: 2 May 2016 12:27 EDT
Issue with Date property using in the Case match rule
FR
Well I haven't done much really:
1) Create a date property called "TestLassmDate"
2) Create a case match called "CaseMatchLassm"
3) Add the property into the case match and save the rule.
Pegasystems
When I click on your first picture, it pops up but doesn't get any bigger, so I can't see your error message. I'm curious, did you paste it with firefox ? If you use a file to put picture in first, does it make it work better ? /Eric
CGI
CGI
I am still waiting for solution. Please help us in resolving the issue.
Thanks & Regards
U Rajasekhar
FR
CGI
Hi Marc,
We are using Pega 7.1.7.
Thanks & Regards
U Rajasekhar
CGI
Could someone provide solution.
Thanks in Advance.
Best Regards
U Rajasekhar
FR
I tried the same configuration on Pega 7.1.7 and I can save the rule as expected. Can you try to recreate it from scratch with just the "Date" property and nothing else.
CGI
Thanks Marc,
We will try creating new date property and update you.
Could you please share the steps you followed to test? It will help to compare.
Best Regards
U Rajasekhar
CGI
Hi Marc,
Could you please share the steps you followed to test in Pega 7.1.7? It will help to compare.
Thanks & Regards
U Rajasekhar
CGI
Hi Marc,
Thanks & Regards
U Rajasekhar
FR
CGI
Thanks Marc......
