NewCorp / Asurion
Last activity: 2 May 2016 5:15 EDT
What is the config setting/DSS that control soap over JMS time out?
The setting on the connector rule form doesn't work with SOAP over JMS calls.
just examine the invokeaxis2 activity, you will see all the logic regarding JMS setup and the related classes (part of 3rd party jar praxis2JMSTransport.jar shipped OOTB). In theory, if you modify invokeaxis2 to set the SOJSpecConstants.JMS_WAIT_REPLY option in the client setup step (for 7.2 step 7), it should work.
not aware of any DSS. Your endpoint url needs to start with "jms:". And you need to define a Data-Admin-Connect-Transport-JMS defined in the Connect-SOAP JMS Transport field.
What version of prpc are you running? Are you saying the timeout value does not work?
NewCorp / Asurion
We are on PRPC 7.1.7. Timeout defined on the Connect-SOAP is 120 sec but the service times out after 30 sec.
This appears to be matching the JMS default timeout (30 secs). Let's wait for SMEs comment if that is expected behavior or not. Another question is, where to specify JMS timeout? I saw that in the code the default value is 30 seconds.
JP
Hi Kevin Zheng / SME
We have a reported instance of Connect-Soap timeout after 30 seconds [even when higher value is set in the rule], for 6.2 SP2 [A14781].
Could you kindly elaborate about the default JMS timeout 30 in the code, where you are seeing it.
Regards and Thanks,
Tarun Sipani
I was referring to this constant:
SOJSpecConstants.DEFAULT_JMS_TIMEOUT;
which has the value of 30 secs. This is used by SOJSpecSender class. In the code, this will be overridden by the value of SOJSpecConstants.JMS_WAIT_REPLY if that is set. Otherwise, the default value will be used.
JP
Hi Kevin Zheng
Thank you for the reply.
1) Could you kindly share the fully qualified [with package name] of this class you are referring to . [is it in a contained jar file?]
2) Also https://community.pega.com/support/support-articles/how-change-response-timeout-connect-soap-rule-runtime mentions about updating timeout in step 7 , would it be useful in this case.
Regards and Thanks,
Tarun
JP
It is a standard java compilation error, try to use the fully qualified name of the class.
JP
Thanks much Kevin, that helps a lot.
Tarun
