Tabbed Screen Flow - Cancel Option - Client Side Validation Error
I am using 7.1.5
I am using TabbedScreenFlow7 harnesss and wanted an option to Cancel the case when in the screenflow.
I accomplished the same by adding a Cancel button to the TabbedScreenFlow7 harnesss and configuring the button for the following Actions OnCLick.
Run Activity - CancelScreenFlow
Finish Assignment
And I have configured an Assignment in the same flow from which screenflow was called to catch the Withdraw ticket that would be Set by the CancelScreenFlow activity.
It seems to be working fine.
But if there are fields with Client Side validations ( like required fields ) in the UI - we are getting the error 'Please correct flagged fields before submitting the form' on click on the Cancel button.
But the actual Cancellation of the case takes place. So even after we get this error if we just close the case tab and open the case again, it would have moved to the assignment where the Withdraw ticket was Set.
I have tried different options in the below link - but none of them is working for the TabbedScreenFlow7 harnesss.
I am using 7.1.5
Finish Assignment
The only option that worked was Disabling the 'Client Side Validation' on the Advanced tab of the TabbedScreenFlow7 harnesss - but this will have the issue of the validations errors NOT being shown till the Submit is done - which spoils the UI experience.
Please let me know if there are any other workaround for the same.
