Infosys
Last activity: 6 Apr 2017 11:45 EDT
Can anyone provide me with the docs for learning pega with Handson examples so that i can able to understand the concepts much better.
Hi Praveen,
Thanks for sharing the actual need of yours.
If you have gone through the courses, you also might have downloaded the VM and completed the exercises using the exercise guide provided within the course. If you have not done please go to the course and download the VM, Student Guide (555 pages), Exercise guide and complete all the exercises.
In order to get thorough/detailed knowledge you have to read through the following courses and complete their exercises in the following sequence:
Technical Track Pega 7:
System Architect Essential I
System Architect Essential II
Senior System Architect
System Admin Specialist Course
Lead System Architect Course
Business Track Pega 7:
Business Architect Essentials
DCO Essentials
Running A Pega Project
Specialist Courses
UI Specialist (This course would detailed on UI Design and implementation only)
Hope this helps to get a detailed knowledge about Pega 7.
If you want to get more details on specific topic then please go to this link and explore the help contents.
Hi Praveen,
DCO Essentials
Specialist Courses
https://pdn.pega.com/support-downloads/pega-help-systems
If you want to get the detailed help about a specific Rule type then open the Rule Instance -> Go to Action menu and choose get help menu option. This is called as Context sensitive help.
Sarada
Hi Praveen,
Have you tried Pega Academy on the PDN?
Here is the link: https://pdn.pega.com/about-pega-academy
Tagging Sarada Satapathy from Pega University here!
Lochan
Hi Praveen,
As you are working with TCS you can access the full content in Pega Academy.
Please go to https://collaborate.pega.com/ and register yourself using your TCS email id. Once you receive a confirmation from our PDN team, you can login back to PDN using https://collaborate.pega.com/ . PDN stands for Pega Discovery Network. Please go to Academy menu -> Choose My Self Study -> You would see course Library -> Choose By Product -> Choose Platform -> Choose System Architect essential I course -> enrol to the course.
After enrolling to the course you would be able to access the lessons in the course -> Please go through the first 3 to 4 lessons of the course in detail. This will guide you to download the Course material, lab exercise guide and Exercise Environment in the form of VM. Download procedure of the VM and usage of the VM is also mentioned in these lessons mentioned in the above lines.
Hope this information would help you.
Regards
Sarada
Infosys
Hi i have access to pdn and i had gone through the courses also.I am having a little idea about the things,for getting a detailed knowledge and expertising in the concepts i am in search of detailed docs and tutorials so that i can know the concepts in detail.
Hi Praveen,
DCO Essentials
Specialist Courses
Hi Praveen,
DCO Essentials
Specialist Courses
Sarada
Infosys
Thank you..
Hi Sarada,
Can you please provide the exact link for Student guide.
