TD
Last activity: 10 Jan 2017 11:05 EST
HFix-9120
Hi Team,
Could you please provide us the steps to install HFix-9120 in PRPC 5.5 version and also HFix package?
Chandra
Hi Chandra,
Unfortunately Oracle 12C is not supported for PRPC 5.5. Support for Oracle 12C isn't provided out of the box until Pega 7.1, and the hotfix you've noted introduces support for Oracle 12C for 6.3 SP1.
Per the Platform Support Guide (https://docs-previous.pega.com/platform-support-guide-prpc-5x-and-6x):
PRPC and newer Platform Components: It is Pegasystems’ policy not to backwards-test new versions of Platform Components with older releases of PRPC. Support for new platform products is provided through newer versions of PRPC software. If you choose to upgrade Platform Components to the latest releases, but want to stay on older releases of PRPC, you may enter support requests for any problems encountered. However, if the root cause of these problems stems from the fact that the older versions of PRPC were not designed to handle functionality in the newer Components, Pegasystems may request that you upgrade your PRPC version to a release that directly supports that newer Component, as listed in this Guide.
PEG
You should create SR with Pega GCS to get the Hfix package and readme.txt file contains steps to install the Hfix.
https://collaborate.pega.com/question/how-raise-sr-my-support-portal-how-question
Hi Chandra,
Were you able to create an SR with Request Type as Media Request?
I am curious to know your use case for this HFix since it looks like an internal hotfix for PRPC 6.3 SP1
Lochan
TD
o I have created the SR SR-23307<https://gcssupport.pega.com/pr3web/PegaSupport/A5ikzsG0BTMHfVeE1djqyfuZL6DnSwYp*/!STANDARD?pyActivity=Work-.Open&Action=Review&InsHandle=ATPEGA-TASK+SR-23307> as Media request.
We are trying to upgrade only database from Oracle 11g to Oracle 12 C on PRPC 5.5.
Chandra
Hi Chandra,
Update Note: https://gcssupport url is being retired. Use https://gcsprd.pega.com going forward.
