update from 7.1.8 to 7.2 fails
after using the force option to push the update (as we had a hotfix installed which blocked the update)
# ran with force option
force.ml.update=true
the build eventually failed ...
BUILD FAILED
/prpc/scripts/setupDatabase.xml:380: The following error occurred while executing this line:
/prpc/scripts/setupDatabase.xml:2706: Java returned: 1
Total time: 34 minutes 46 seconds
Ant Process returned a non 0 value
380 is:
<antcall target="Update Finalization">
<param name="mode" value="upgrade"/>
</antcall>
2706 is the java step in this target:
<!-- Target which prebuilds the Pega Conclusion caches into the database -->
<target name="Prebuild Conclusions" if="build.conclusions.set" unless="completed.steps.PrebuildConclusions">
<timestamp.start message="PrebuildConclusionsRuntime" property="PrebuildConclusions_start" />
<java classname="com.pega.pegarules.pub.PegaRULES" fork="true" failonerror="true">
<classpath refid="prpc.base.path" />
BUILD FAILED
380 is:
</antcall>
<jvmarg line="${jvm.args}" />
<sysproperty key="com.pega.pegarules.bootstrap.properties.url" value="file:///${prbootstrap.config}" />
<sysproperty key="com.pega.pegarules.bootstrap.ignorejndi" value="true" />
<sysproperty key="pegarules.config" value="${pegarules.config}" />
<arg value="com.pega.pegarules.exec.internal.basic.dictionary.ConclusionCacheImpl" />
</java>
<timestamp.end message="PrebuildConclusionsRuntime" property="PrebuildConclusions_end" />
<resumecheckpoint targetname="PrebuildConclusions" />
</target>
Log file output:
Buildfile: /prpc/scripts/setupDatabase.xml
update:
Initialization:
Checking Configuration Files:
Processing Configuration Files:
Configuration:
Verify ML Readiness:
PRPC_Rules build date: 2016-02-03 19.54 EST
The following code modules were updated after this release was built:
DataSetMessageProcessor.class com/pega/dsm/dnode/impl/server 2016-03-07 18:12:30
... 374 classes from hotfix-26359
Cleanup RuleSets:
Generate RuleSet Cleanup Script:
Generate Upgrade DDL:
_clean:
_createOutputDirs:
_callDDLUtilityUpgrade:
generate_upgrade_ddl:
Check zOS Upgrade:
Schema Upgrade:
Schema Upgrade Inner:
Apply UDFs:
Apply UDFs Inner:
Install UDF Jar:
UDF Generation:
installUDF:
Engine Load:
Engine Load Inner:
Reorganize Database Indexes Preupgrade:
Remove Invalid Settings:
_upgradeRuleBase:
Rules Upgrade:
Reorganize Database Indexes:
Calculate Table Stats:
Upgrade Rule Messages:
Generate Declarative Indexes:
Remap Database Tables:
Import Assembled Classes:
Log Schema Meta Data:
Import Updates:
Update Existing Applications:
Run Assembler:
Prebuild Conclusions:
Errors occurred in a number of targets, starting in _upgradeRuleBase:
- Unable to obtain DataSource for adestaging: java:comp/env/jdbc/adeStaging
- Unable to obtain DataSource for adestagingprod: java:comp/env/jdbc/adeStaging
- Clustering has been disabled on this node by setting 'identification/cluster/protocol' to 'none',
however the protocol currently being used by the cluster is 'hazelcast'.
This inconsistency will cause functionality that uses the cluster to fail on this node which
can lead to data consistency problems and potential data loss.
This node should be shutdown and restarted with clustering enabled.
I do not think these are critical.
the failure occurred in Prebuild Conclusions:
- Building Conclusion caches.This process might take few minutes...
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-SALES
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-SALES of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-SERVICE-COMPLAINT
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-SERVICE-COMPLAINT of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-TESTISSUE
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-TESTISSUE of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-SALES-HANDSETS
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-SALES-HANDSETS of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-TESTISSUE-TESTGROUP
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-TESTISSUE-TESTGROUP of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-RETENTION-PROACTIVE
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-RETENTION-PROACTIVE of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-SERVICE-ACCOUNT
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-SERVICE-ACCOUNT of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-NEGOTIATION-NEGOTIATION
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-NEGOTIATION-NEGOTIATION of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-NEGOTIATION-ADDONS
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-NEGOTIATION-ADDONS of type, Class
ERROR -
ERROR - com.pega.pegarules.pub.PRRuntimeException: Unable to initialize a ClassInfoConclusion for PEGAMKT-WORK-OFFER-NEGOTIATION-HANDSETS
ERROR - Unable to build Conlusion, PEGAMKT-WORK-OFFER-NEGOTIATION-HANDSETS of type, Class
ERROR - Stopped building conclusions of type, Class due to continuous exceptions
ERROR - caught exception during build of Pega conclusions
the server did startup post update, but logged an error (however this error was existing prior to the update)
org.apache.catalina.startup.ContextConfig processAnnotationsJar
SEVERE: Unable to process Jar entry [com/pega/eclipse34/jdt/internal/compiler/ast/QualifiedNameReference.class] from Jar [jar:file:/var/apache/apache-tomcat-7.0.57/webapps/vbd/WEB-INF/lib/preclipse-compiler-3.4-7.1.8-SNAPSHOT.jar!/] for annotations
java.io.EOFException
I can log in and the UI shows 7.2 ... so the question is ... what failed in the update, is it a serious failure, and how do I fix it.
this has all been done in a VM, which I have a backup of, so I can repeat the process at will.
for prebuild conclusion errors: see this link: https://community.pega.com/support/support-articles/error-prebuilding-conclusion-task-during-upgrade Essentially there are some invalid classes listed, you need to manually correct them.
