In layout group is there a way to Show the actual errors instead of showing "error" on top of all tabs
Here, error is shown on press of submit but end user doesn't know in which tab error is present
End user must scroll through each tab to know where error is present
Solution:
Either instead of showing "error" on top of all tabs, the actual errors(say, value cannot be blank) or an exclamation is to be thrown on the tab having error
Hello Aditya Boggarapu,
There is already a feedback item FDBK-15411 created for this behavior.
Best Regards,
Mounika
Hello Aditya,
For what version of PRPC are you observing ?
I have tried replicating in our local 7.2 system and I could observe the same i.e it displays "Error" for any type of validation error.
I am looking into the behavior and will update here with my progress.
Best Regards,
Mounika
Hello Aditya,
Upon analysis, could observe that the code has been written is such a way that if there are any errors, an error table is created (if it does'nt exist already) and then sets the message. The message here is hardcoded to "Error".
Best Regards,
Mounika
Hi ADitya
Are you using client side validations on a tabbed group layout ?
1. If yes, can you check if a post-action activity instead of client side validations help ?
2. Not sure whether this applies to your scenario : https://community.pega.com/support-articles/no-icon-tab-indicate-error-0
The steps to reproduce talks about a tabbed screen flow, which in my opinion is a typo and should have been a tabbed group layout. I'll verify.
Yeah, we are using layout group: tab ; There are two validations in our case.
in tab 1, Entering yes/ no radio butons field is made as mandatory
in tab 2, In activity, which runs on a local save button of that particular tab, property set messages in done in a step in activity, which sets error messages on property, when it is empty
Hi Aditya
Locally I have noticed that when using Page-Set-Messages on post action activity does mark the tab on which the issue is.
how are you calling the activity with Property-Set-Message ?
Can you try post action activity + Page set message and check if the issue is addressed ?
Best Regards,
Mounika
Aditya B
![](https://accounts.pega.com/sites/default/files/pega-user-image/35/REG-35180.png?source=PUMINIT)
Capgemini America INC.
HI Mounika Thatikonda, has this FDBK-15411 been implemented yet?
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689877000/122ddbf9-8ed7-431e-8c0c-0892f658c39d.png?itok=HwmzfVHs)
The mentioned feedback item(FDBK-15411) seems to be implemented in 7.2.2.
Aditya B
