![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-11/46daa9d6-f3fb-42ad-b6a5-95eecc782bf3.jpg?h=bda26cd1&itok=sy_eLS1O)
Areteans
Last activity: 3 Mar 2017 17:14 EST
Unable to extract access group from URL for static content request from request /images/x-sprites.png requestor
Hi Team,
I am getting the following error message frequently in log file of Production environment:
"Unable to extract access group from URL for static content request from request /images/x-sprites.png requestor=H989E2FE4F4FA06284AF57F0A2083A195 referrer"
Can someone please tell me the root cause for this log message.
Thanks & Regards,
Divya Sri Padarthy.
Message was edited by: Marissa Rogers - added category
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689956000/c7d8436c-e407-494e-a0b9-3e4520220ba6.jpg?itok=V-E9m_lT)
Hi Divya, Its a HotFix-8818
Updated: 15 May 2016 13:10 EDT
Hi Divya, Good morning!
- I think, system is trying to access an invalid rule of type 'Rule-File-Binary'.
- As it is static content cache we could try clearing from
- browser cache and if error persists
- check the value for http/defaultcachingtimeout setting in prconfig.xml
- on server we need to diagnose staticcontent/.../global [..\Tomcat7063\Temp\StaticContent\autogenerated\Rule-File-Binary] folder to invalidate this file.
- also please confirm if the agent StaticContentCleaner is running or when did the last run happened.
Please share your comments/thoughts, Thank you!
psahukaru
Areteans
Hi Phani,
I will surely try the solution provided by you and let you know.
Divya Sri Padarthy.
Hi Divya,
Could you please mention the PRPC version, we had provided a hotfix for PRPC v6.3.1. If the URL contains asterisk or some special characters like ", ?, *, <, >, |, : , the path of URL is not formed properly and Error in static content path prevents file from being served and hence causing the issue.
Areteans
Hi Basavaraj,
we are using PRPC V6.3 SP1.
Can you please provide the hotfix number.
Divya Sri Padarthy.
![](https://accounts.pega.com/sites/default/files/pega-user-image/209/REG-209263.png?source=PUMINIT)
Hi Divya,
Please find the steps to obtain the HotFix in the article here: Raising Support Requests for Hotfixes now made easy!
Basavaraj Kadakol - Thank you for sharing the hotfix details.
~Vidyaranjan A V | Community Moderator | Pegasystems Inc.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-07/f7f35052-5e7d-4ed9-ada9-87594f1d3c63.png?itok=bz3Ms_gZ)
Hi Divya,
Please share the SR number once created to obtain the Hotfix.
Thank you!
Areteans
Sure Marissa.
![](/themes/custom/pegacc_theme/images/user-icon.png)
Hi Divya,
Did you ever raise the SR?
Lochan | Online Community Moderator | Pegasystems Inc.
Areteans
Hi Lochana,
I haven't created SR yet, i will update once i create.
Divya Sri Padarthy.
Hi Divya,
Sure! Thank you
Lochan
JABIL
Hello Friends,
We are seeing this error "Unable to extract access group from URL for static content request" when trying to open the function builder in a report definition. We are using pega 7.1.9 This doesn't happen in development environment , but only staging .
Is the hotfix 8818 applicable to pega 7.1.9 . I believe the error is because of a malformed request url (with any special symbols) . In one other thread , I found commenting below lines in web.xml would fix it. Is that what the hotfix does too?
Comment out the following from web.xml (found in prweb.war within the ear file).
<servlet-mapping>
<servlet-name>WebStandard</servlet-name>
<url-pattern>/*</url-pattern>
</servlet-mapping>
Hello Friends,
<servlet-mapping>
</servlet-mapping>
Appreciate any helpful information . Thanks in advance!
-Santhosh
Areteans
Hi Santhosh,
This issue what we are facing is in PRPC 6.3 sp1.
And the hotfix was working for us.
You can check with support team, whether this hotfix will work for 7.1.9
Divya Sri Padarthy
JABIL
Hi Divya,
Thank you for the response. We will check with the support team , but meanwhile could you please let us know the change that is in the hotfix ? I want to try it out in my private edit and see if its going to work.
Thanks Again!
Hi Santosh,
Please compare the hotfix inventory of both Staging and Development and check whether there are any hotfixes that are causing the issue.
As per the corresponding Bug item raised for Hfix-8818, this is supposed to be fixed in Pega 7.1.
Let us know the results.
Best Regards,
Mounika
