Salame
Last activity: 23 Jun 2016 12:59 EDT
Harness for the non final stages
I have a case type that contains 3 stages; each has one process.
How to add a harness for the first two stages so, we can have only 2 buttons "Next", "cancel" that allow us to move to the next stage?
Thanks in advance,
Rosy
Salame
Can someone help please?
Rosy
![](/themes/custom/pegacc_theme/images/user-icon.png)
Hi Rosy,
Can you please provide few more details which might help resolve this:
PRPC version and some screen shots of what you actually see now.
-Shan
Salame
Hello Shan,
I"m using PRPC 7.2. I have just created a new case type. assigned my flow action of the first stage to a dummy section and I have run my case, I have obtained below. I just want to display the highlighted section without the rest (my section + "Next" button instead of "Submit"), which harness should I need to use ?
Thank you,
Rosy
Updated: 2 Jun 2016 4:27 EDT
Pega Systems
For first two processes
- Update the flow actions. Check the "Hide the default action section buttons" checkbox.
- Configure the "Next" and "Cancel" buttons on the sections (referred by above flow actions).
"Next" button configuration
- On click: Finish Assignment
"Cancel" button configuration
- On click: Cancel
Salame
Thnaks Sarang for your answer, however, I don't want to rename buttons only, but, I want to get rid of the Standard section (Case details ... in above. I only want to have my section on the screen ) how to do that?
Rosy
Updated: 2 Jun 2016 4:54 EDT
Pega Systems
Save as "pyCaseContent" section (which internally refers to "pyCaseActionArea" section) in your RuleSet and update it as necessary.
NB: You can use Pega given "Live UI" tool to identify different sections.
Salame
Thanks Sarang, I will try that and will keep you posted.
Rosy
Also, using Live UI, you can find the harness you are currently using and do a save as of it and you can customize it to have only the highlighted section.
Salame
Thanks Shanmukha, I will try that and will keep you posted.
Rosy
Salame
