PayPal
Last activity: 3 Jun 2016 12:38 EDT
Can we access local variables of an activity in a called data transform ?
there is a final activity that calls a data transform which is an extension point. I want to access the local variables of the calling activity in my data transform to do some processing ... Is there any way to do that ?
End requirement :-
On upload of an image in an RTE (rich text editor), I want to check the size of the inserted image, the moment it is uploaded. There is a OOTB final activity that is going to upload the image file and it being final, I cannot modify it. It calls a data transform that can be used to set an message to user.
Updated: 3 Jun 2016 12:20 EDT
Hi Nishan,
If I understand what you want to do here: which is use a Data Transform to set local values in a calling Activity - I don't think there is any way that you could achieve currently.
In your case: I think the only solution is make a copy of the Final Activity in question (effectively re-implementing the Activity in a way that suits your requirements): or logging a request to GCS - so see whether this Activity could be 'de-finalized' (if that is feasible and a doesn't have other consequences down the line somehow).
Cheers
John
I could be wrong in this : but here's what I tried: and my findings to show why I came to this conclusion:
I tried to create a simple Data Transform that sets a Local scope variable - the Designer Studio prevents me from doing this:
Furthermore the 'Parameters' Tab for a Data Transform doesn't let me define any Local scoped values (unlike Activities):
Hi Nishan,
Cheers
John
Compare that to an Activity,
So on the Params tab; we can define a Local scoped variable : 'a' of type 'String':
And on the Steps tab we then use a Property-Set step to set the value of 'Local.a':
This saves without issue - and (even though I didn't actually run it : I expect it will work).
Now we take a look at the Generated Java for this Activity:
And search for declaration of our local variable; this is what we find:
public void initializeStandardLocalVariables() { nextBlock = ""; pz_Status = true; pz_methodStatusUpdated = false; debugIsOn = false; forEachCounter = 0; pz_forEachSkipClass = 0; infEngine = null; nextProperty = null; pz_CurrentRuleKey = ""; pz_CurrentCircumstance = ""; pz_CurrentStepNum = ""; pz_CurrentTraceInfo = null; pz_thisPageClass = ""; pz_Dictionary = null; statusReturnedFromNestedLoop = ""; } public String a = ""; [...]
So, here's my understanding here of why you can't (currently at least) do this in PRPC:
1. Data Transforms don't seem to have any concept of a Local variable - there is nothing on the Params tab, and the syntax Local.variable is not understand.
2. The Local variables defined on Activities are scoped strictly to the Activity itself: they are implemented by defining a Java Field within a Class when the Rule is saved/assembled.
I *guess* what you are after might make a good enhancement: but you would need to 'spec' out exactly how this mechanism would work.
How would the Data Transform know which Local Scoped variables it is able to modify ? (the Design-Time Form would have to contain something that made it aware of calling Activity in order to know what Locals is allowed to modify : or else it would have be totally 'liberal' in what it allows: and then you are trading a design-time syntax-check for a runtime-check (what to do when a non-scoped 'local' isn't available ?)
But then: this is probably the main reason for having a Parameter Page - to avoid having to 'leak' Local Variables from Rule-To-Rule...so it's dubious that an enhancement would bring much additional flexibility here... (but maybe it would ? dunno).
Random follow-up notes:
It is notable that the Local 'a' in the example has a 'public' modifier: so in *theory* outside Java Classes can 'get to it' : but they would still need knowledge of the enclosing scope to know that it exists...
It is also telling that the error you get when trying to save a Data Transform that contains a 'Set' action for a 'Local.<variable>' syntax gives this:
This record has 1 Error in 1 place — Test compilation failed: ---------- 1. ERROR in /Rule_Obj_Model_Gcs_scratch_Work_TestDT_Model_20160603T155957_547_GMT.java (at line 60) a = "hello"; ^ a cannot be resolved to a variable
That is: it appears that the DT does recognize the 'local' prefix, - because the error has managed to parse it out; it essentially knows we are trying to modify a local variable - it's just that the variable happens to not exist; and we have no way of defining any.
Even IF there was a way of setting up a Local Variable on the Params tab of the DT: that wouldn't solve any issues though: you still wouldn't be able to pass in any Local Variables.
The more I think about this: I actually think its a good thing that DTs (or any other called rule) cannot try and modify the Local Scoped variables of the calling variables : this could lead to very difficult to debug issues.....
Pega Systems
You can send Local variables as parameters to the Data Transform.
PayPal
the problem is that, then these need to be passed as parameters in parameter page. but wont i be able to pass local variables as is ? because the calling activity here is a final pega ootb activity and i cant modify it.
Hi Nishan,
Cheers
John
Hi Nishan,
Cheers
John
PayPal
Thanks a ton Jon for the elaborate explanation.
